General Troubleshooting Issues and an error, every time the truck sits for too long it needs a jump, and the battery was replaced last year brand new?
2004 FORD EXPEDITION
245,270 MILES • 5.4L • 4WD • AUTOMATIC
JUDIESIMMONS92
  • 19 POSTS
So, I have the vehicle listed above XLT 5.4L Triton 16V 8 cylinder.
The Troubleshooting Issues:
1 Every time the truck sits for too long it needs a jump, and the battery was replaced last year brand new
2 Will a tune up and oil change make the car run a little bit unusual then on top of it already needing the tune up and oil change
The Big Error:
I accidentally put 1 quart of transmission fluid in the oil full synthetic transmission fluid in the oil I looked it up on Google it said that's not a bad thing just put a quart on oil in with the transmission fluid and it will act as a cleaner to the engine this was about 3 weeks ago now
Ending:
So, what is my solutions to these Issues and Error?
May 8, 2024 at 4:29 AM
We only handle one problem per thread. Please start new questions for the tune up and transmission fluid issues. The battery draw sounds like the A/C compressor clutch relay is stuck on. so, I would remove it to see if the drain goes away, here is the location of the relay and a guide to help you go over the easy fixes for the is as well.
https://www.2carpros.com/articles/car-battery-dead-overnight
May 8, 2024 at 1:07 PM
