Gearshift not working properly
2012 AUDI S4
150,000 MILES • 3.5L • V6 • AWD • AUTOMATIC
LEKONE
While driving, it takes all gears but when I release the accelerator it kicks back to neutral and it does not have any fault codes. what could be the problem?
Apr 2, 2017 at 12:03 PM
There are several fuses I would check first, here is a wiring diagram that can help you see the fuses involved. Next I would scan the transmission or codes here are a couple of guide that should help you.
and
It could be pressure sensor or a shift solenoid there is no way to tell until you read the codes.
Please run some tests and get back to us so we can continue helping you.
Best, Ken
Apr 4, 2017 at 2:44 PM
