Gears not working
2001 FORD GALAXIE
120,000 MILES • 2.3L • 4 CYL • 2WD • MANUAL
RUSTYRED11
I have 1st and 2nd gear but won't go into 3rd 4th 5th or reverse
Feb 8, 2016 at 1:17 PM
HMAC300
  • 48,601 POSTS
we dont' have that model in USA but check linkage for correct adjustment.If it will shift to gears with engine off probably a clutch problem if it won't shift with engine off then may be an internal problem like a schyncro or bad forks etc. also if cable operated may be a bad cable
Feb 8, 2016 at 3:46 PM
