Gearbox Swap?
1998 FORD FIESTA
357,000 MILES • 1.4L • 4 CYL • 2WD • MANUAL
SHOWENVANWYK
  • 10 POSTS
Will my Fiesta 1998 1.4 CVH-PTE gearbox fit on a Fiesta 1997 1.3 Endura E engine? Both gearbox part numbers are almost exactly the same. My fiesta 1998 gearbox part number is 96WT-7F 096DB And The 1997 Gearbox part number is 96WT-7F 096CB.
Jan 24, 2025 at 7:36 AM
Yes, the gearbox from your 1998 Ford Fiesta 1.4 CVH-PTE is likely to fit the 1997 Ford Fiesta 1.3 Endura E engine, as both gearboxes share almost identical part numbers. Be sure to check the electrical connectors and CV axle input shaft splines. Also check the clutch input shaft spines as well.
Jan 24, 2025 at 10:55 AM
SHOWENVANWYK
  • 10 POSTS
I'm going to upload two pictures of the cvh gearbox and the endura gearbox. I see they have a slight difference.
Jan 24, 2025 at 10:58 AM
SHOWENVANWYK
  • 10 POSTS
1
Jan 24, 2025 at 10:59 AM
SHOWENVANWYK
  • 10 POSTS
2
SHOWENVANWYK
  • 10 POSTS
Is it possible to build over inner parts from the 1.4 cvh pte to the endura 1.3?
Jan 24, 2025 at 11:00 AM
It is hard to tell if it will work, they look similar but you need to look at both in person.
Jan 25, 2025 at 4:17 PM
SHOWENVANWYK
  • 10 POSTS
Okay thanks.
Jan 25, 2025 at 10:47 PM
You are welcome, please use 2CarPros anytime we are here to help.
Jan 26, 2025 at 9:43 AM
