The vehicle has a park interlock system. I will try my best to help.
The interlock solenoid is to release the shifter when you apply the brakes. What happens is this. When you press the brakes, the brake light switch turns the brake lights on and at the same time, powers the interlock solenoid to release the shifter. First, check and confirm the brake lights are working for me.
Next, if the brake lights work, we will need to check to see if power is going to the shift lock interlock solenoid. Let me know if they work,
In the event you can't get it to shift out of park, there is a manual override. Here are the directions and the attached picture shows where the override is located:
____________________
BTSI Override
In the event of an electrical failure, the vehicle can be shifted out of PARK by using the following procedure.
1. Turn the key to the ACC or ON position.
2. Remove the liner to the cubby bin to the right side of the shifter.
3. Depress the BTSI override (2) on the side of the shifter assembly (1).
4. While the override is depressed, move the shifter out of the PARK position.
5. Return the cubby bin liner to its original location.
I will watch for your reply.
Dec 26, 2018 at 6:59 PM
