Gear shifter broken
1999 CADILLAC ESCALADE
180,000 MILES • V8 • 4WD • AUTOMATIC
BECKI LANDIS
Do not know what the name of the part. Son in law broke the on the column gear shifter.
Jun 27, 2018 at 6:08 PM
DANNY L
  • 5,648 POSTS
Hello, I am Danny.
Yes, it is called the "shift lever" and is replaceable. I am attaching a diagram that shows the components. You need to remove the upper and lower plastic covers to gain access. The cover is held together/attached with a few screws. After removing covers the shift lever is held to column with one screw. Shift levers are available at your local Dealership or Wrecking yard.
Danny-
Jun 27, 2018 at 6:41 PM
STEVE W.
  • 15,113 POSTS
As Danny says they are replaceable. This image is a bit larger. To remove the lower cover you will need to pull the tilt lever out of the column, just use some padded pliers or if you have a good grip just pull the lever straight out. If he broke the casting that the lever goes into and not just the tip on the lever then it is a bit more involved.
If he broke the grip section it is easier to replace the entire lever as, although they are supposedly just "push on", every one I have tried that with ended up split. Even when I soaked them in hot water to make them have a bit more stretch.
Jun 27, 2018 at 8:45 PM
