Good morning
No, all the additives necessary are already in the fluid you are adding to the differential.
Type
Front .................... Motorcraft SAE 80W 90 Thermally Stable 4X4 Axle lubricant
Rear .................... Motorcraft SAE 75W-140 Synthetic Rear Axle Lubricant
Capacities
Capacity
Front .................... 1.54L (2.7 pints) 9.56 mm (0.38 in)
.................... below the bottom of the filler hole
Rear .................... 2.60L (5.5 pints) (6-14 mm (1/4-9/16 in)
Oct 25, 2018 at 3:43 AM
