I am only finding the spec of 2.7 litres for all transmission but it appears there was an option of different transmissions. However, due to not finding any info other then 2.7 litres for all transmissions, that is what I would go with. Does your transmission have a fill plug? If so, this should be correct. However, if it does not have a fill plug then they say it needs to be filled through the speedometer gear hole. However, this appears to only be for the 2.8L engine so your spec should be 2.7 litres.
Sorry for not confirming this because we don't have a manual for this vehicle as it is not offered in the USA.
Let us know if you have other questions. Thanks
Sep 28, 2020 at 3:02 PM
