gear box oil change
2012 KIA CERATO
225,000 MILES • 2.0L • 4 CYL • FWD • AUTOMATIC
KIA FORTE 2.0 2012
Dears,
Kindly help me. How do i change my gear box oil ?
Jun 21, 2016 at 3:46 AM
There is a drain at the bottom of the transmission pan. If yours doesn't have a drain plug, the pan will need removed. Do it slowly so the ATF doesn't go everywhere. Once it's removed, drained, and a filter is replaced, reverse the process. NOTE: Do not overfill the transmission and make sure to use the correct fluid. See your owner's manual if you have questions.
Jun 23, 2016 at 7:39 PM
KIA FORTE 2.0 2012
It doesn't has a drain and no way to know the oil level not like the engine
Jun 23, 2016 at 11:27 PM
KIA FORTE 2.0 2012
If you have a video how to do it i will be greatful to you, thanks for you reply
Jun 23, 2016 at 11:29 PM
Hi, I found this for you, it looks like you have a plug in the side of the cover that determines the oil level
Let me know what you find out
Best, Ken
Jun 25, 2016 at 8:31 PM
