First off vehicle runs perfect. I was driving home from work and heard the "low fuel" chime and immediately looked down at the instrument panel, sure enough the "no gas" light was on. Well I knew I wasn't low on fuel (just put half a tank in) and that's when I noticed none of the gauges were working. everyone of them were flat lined. Mined you I was still driving but neither tachometer or speedometer gauges were working as well as the fuel, voltage, oil pressure or coolant etc. The only signs of life were the illuminated "low fuel", "check gauges", a yellow circle with a key inside and a slash through it and the digital odometer. I will try to upload a video or at least a picture. This is the third Jeep I've owned (1999-2005 model) and never have I seen the key symbol before. ignition switch/sensor maybe? Any ideas or answers would be appreciated!
Feb 21, 2019 at 10:36 AM
