I bought the car listed above GTP Coupe almost a month ago as my first car for my last year in HS. It has the supercharged 3.8 3800 V6. It needs premium gas (91-93) because of the lower compression and supercharger. The previous owner and the dealer I purchased from filled it with 87. At around 3,500 RPMs the engine shook really violently and threw a P0304 engine code, which is a cylinder 4 misfire code. I filled the tank with 93 and have been running it that was since, and the issue has kind of fixed itself, but not totally. it still does it at highway speeds and still at around half throttle. From what i've read, this is premature fuel detonation, but I cant find a permanent fix. I have a friend with a 98 Regal GS and he has the same issue. I've replaced the fuel filter, used injector cleaner on gas fill ups and new spark plugs and wires. Do I need new injectors? ECU reprogram? Fuel system flush? I need to kill this issue before I start doing any serious performance mods, as I plan on adding an intercooler, a smaller SC pulley and a full exhaust with headers. any help and ideas would be greatly appreciated. :)
Jan 10, 2023 at 11:37 AM
