Gasoline in engine oil?
2003 NISSAN PRIMERA
115,000 MILES • 2.0L • 4 CYL • 2WD • MANUAL
SKAJLET
1. I can smell gasoline in engine oil and around throttle body as well.
2. When I rev the car on idle to 3,000 RPMs and let go, it goes down to 200-300 RPMs and almost goes out. It feels like something is taking the air out of the engine.
3. It hesitates to increase RPM when I accelerate, but it has power. It loses the power on the hill.
4. I changed spark plugs not so long ago, but they're probably too cold.
5. I checked the resistance on all injectors, and all have around 15 ohms. None of the injectors is leaking on outside.
May 7, 2023 at 2:23 PM
It is normal to smell gas in the oil a little bit, but if the engine oil level continues to go up that is another problem. It sounds like you have a vacuum leak, or the throttle body needs to be serviced. Here are two guides to help us fix the problem. Use this guide when the engine is cold only.
and
Please go over these guides and report back. It would be good to run the codes as well.
May 8, 2023 at 11:16 AM
SKAJLET
The throttle body and MAF sensor were both cleaned. Idle RPMs stay between 600-650.
I scanned the car with OBD and didn't find any errors.
Here are parameters values I found:
- MAF sensor seems to be working perfect it returns around 2 g/s per 500rpm which is ideal according to Nissans service manual.
- the first O2 sensor oscillates between 0.1V and 0.9V, which is perfect as well.
- The second O2 sensor only oscillates with rpms higher than 2000, otherwise it stays on around 0.8V.
STFT and LTFT is where the issue occurs.
- When rpms are higher than 2000, then both values are between -3% and 3%.
- On rpms lower than 2000 and on idle both values are between -10%/15% - 10%/15%.
I wonder if this could be caused by spark plugs 2 heat values higher (cold) than standard?
I wasn't able to find any vacuum leaks. The only thing I noticed was the brake booster hissing slightly when I push the pedal.
May 13, 2023 at 7:56 AM
