P0442 Code check engine light on
1 Replaced the gas cap - made no difference.
2 Replaced the solenoid purge valve next to engine (aftermarket Napa Echlin) and it seemed to fix it for about 6 weeks , check engine light went off, was able to fill tank once normally.
3 Check engine light came on again, P0442 Code again, this time replaced the canister purge valve next to charcoal canister - check engine light turned off. There was no smell of gas and no pellets, tubing from canister to valve was clear.
4 A few days later tried filling tank - same issue gas pump clicks off over and over again.
what should I do next?
Mar 13, 2021 at 9:38 AM
