BOOOOOOO.... Those you have to drop the tank. The coupes have a handy access panel under the rear seats.
Here are the "book" directions:
Release fuel pressure from fuel system.
Disconnect negative battery cable. Raise and support vehicle.
Place a gasoline container (at least 16 gallon capacity) under fuel tank drain plug. Drain plug is located on left edge of fuel tank. Remove drain plug. Allow fuel to drain. Install drain plug, and tighten to specification. (Warning plug does not drain all fuel from tank)
Support fuel tank with a transmission jack. Remove fuel tank strap bolts. Slightly lower fuel tank. Disconnect fuel filler vent tube. Disconnect fuel and vapor lines. Disconnect vacuum line from leak detection pump. Loosen fuel filler hose clamp, and disconnect hose. Disconnect fuel pump module harness connector. Lower fuel tank from vehicle.
Sounds like a piece of cake, until you find the rust and dirt the years add on. Then the nice brittle plastic and hard hoses.
Feb 15, 2017 at 9:10 PM
