So for April fools a group of my friends put a quart of sugar water in my gas tank??! I havnt started the truck but what will happen if I do
Apr 3, 2016 at 8:44 PM
CARADIODOC
CERTIFIED EXPERT
STOP!!! First; get new "friends". Second, remove the gas tank, drain it, then have it steam-cleaned at a radiator repair shop. Sugar will clog the HUGE passages in carburetors, and it will surely clog the extremely fine screens in injectors.
Apr 3, 2016 at 8:54 PM
DABRANAUM
MEMBER
Will my truck start?? In the morning when I need it???!
Apr 3, 2016 at 9:10 PM
CARADIODOC
CERTIFIED EXPERT
It will probably run for up to a minute or two. Don't turn a bad problem into one that will cost more than the truck is worth.
Apr 3, 2016 at 9:15 PM
DABRANAUM
MEMBER
Ok thanks so will it just turn off and not start again or what
Apr 3, 2016 at 9:17 PM
CARADIODOC
CERTIFIED EXPERT
Yes. You'll be walking.
Apr 3, 2016 at 9:33 PM
DABRANAUM
MEMBER
No I'm okay I have a second car. Is it gonna be expensive to fix
Apr 3, 2016 at 9:34 PM
CARADIODOC
CERTIFIED EXPERT
Depends on how much of the work you do yourself, how many brittle plastic fittings on the fuel pump assembly you break, and how much the radiator repair shop charges.
Apr 3, 2016 at 9:52 PM
DABRANAUM
MEMBER
It ran but it was really slow and felt like it wanted to give out! Do you think it will
Apr 4, 2016 at 6:49 AM
CJ MEDEVAC
CERTIFIED EXPERT
WOW!
HE WENT FOR IT!
ARE YOUR FORMER PALS GONNA FOOT THE BILL?
THE MEDIC
Apr 4, 2016 at 4:59 PM
CARADIODOC
CERTIFIED EXPERT
You insisted on doing a lot more damage after I told you what would happen. Now you'll need a set of rebuilt injectors, a fuel filter, and a fuel strainer inside the tank. To be safe, you'll want to replace the pump assembly too. All the fuel lines will need to be flushed and dried. You were really lucky to know about this before you started the engine, but that ship has sailed; . . . well; . . . sank.
