It sounds like you have two separate issues. Do me a favor. Allow the vehicle to sit overnight. In the morning, have a helper turn the key to the "run" position with the engine off. See if you see anything leaking under the vehicle. There could be a steel fuel line that has rusted.
Also, this will give you a chance to determine if the smell is from under the vehicle or under the hood.
If you suspect the fuel pump module at the top of the tank could be leaking, fold the rear seats forward and pull back the carpet. Under the carpet, you'll find a port for the fuel pump. Remove the cover and inspect the fuel pump assembly for leaks. See pic 1 below.
If the smell seems to come from under the hood, do the same thing. With the engine cold, cycle the key to the run position and see if there is any evidence of a fuel leak at the fuel injectors, fuel rail, or the fuel supply line. The only issue with this is the idea that the upper intake needs to be removed to access the injectors. But you should be able to tell if there is one. Pay attention to the supply line and keep in mind there are rubber O-rings at both the bottom and top of the injector that can fail. (See pic 2)
Let me know what you find or if you have questions.
See pics below.
Sep 13, 2022 at 9:41 PM
