OUR FARM TRUCK SHUT OFF ABOUT A YEAR AGO. ITS BEEN SETTING UP. I CALLED 2 DIFFERENT COMPANIES MATCHED COMPUTER UP. SO I REPLACED COMPUTER BRAND NEW ONE. I DONE TRIED ALL DIFFERENT FUEL RELAY SWITCHES. DONE CHECKED SAFE CUT OFF SWITCH BUTTON IS DOWN. I DID PUT A TEST LIGHT ON THE 2 WIRES THAT GO TO IT NO POWER ON EITHER ONE OF THE 2. REPLACE FILTER AND HIGH PRESSURE PUMP EXTERNAL ONE. REPLACE BLACK CANISTER LOOKIN THINK ALSO. I HAVE DUAL TANKS WHICH BOTH WAS WORKING FINE WHEN WE WAS USING THE TRUCK. I SWITCH FORM BOTH TANKS BACK AND FORTH BUT STILL NOTHING. I NARROW FUEL DOWN TO EITHER MY 2 INTERNAL PUMPS IS GONE OUT . OR THERE IS NO POWER TO THE 2 PUMPS IN THE TANKS. WITH A NEW COMPUTER , NEW RELAY , NEW BATTERY, NEW PRESSURE SWITCH, NEW HIGH PRESSURE PUMP, NEW FILTERS AND THE SAFETY SWITCH PUSH DOWN WHY IS THERE NO POWER TO MY 2 PUMPS IN THE TANKS ? THERE IS POWER AND IT DO RUN TO THE OUTSIDE PUMP. IS THERE A DIFFERENT FUSE FOR THE PUMPS IN THE TANKS. THANKS FOR THE HELP IN ADVANCE. I AM GETTING WHIPPED BY THIS FORD. PLEASE HELP
Apr 20, 2016 at 2:59 AM
