Gas leaking into the engine oil
1995 GEO TRACKER
170,000 MILES • 1.6L • 4 CYL • 4WD • AUTOMATIC
WILLIAM MILLER2
Changed fuel injectors. Now the gas is leaking in to the oil. Before change the fuel injectors the gas was leaking out the exhaust.
Jun 24, 2016 at 4:05 PM
Hey William,
It sounds like you might have a system ground that is off, if it all checks out the computer is bad because you have an injector driver that is stuck on.
Here is a wiring diagram that will help you
Let me know what you find,
Best, Ken Lavacot
Jun 25, 2016 at 10:24 PM
