Gas leak, stand by the front of the car, you can smell gas?
2000 TOYOTA CAMRY SOLARA
168,262 MILES • 3.1L • 6 CYL • 2WD • AUTOMATIC
ECKERT-HICKS JANINE
Whenever I use my defrosters the smell of gas comes through the vents. And if you stand by the front of the car, you can smell gas.
Jan 25, 2023 at 3:48 PM
Yep, this is common when the fuel injectors start to leak. I would raise the hood and use a flashlight to inspect the fuel injectors, here are the location of the injectors and how to change them out so you can do the job or see what needs to be done. Check out the images (below). Let us know what happens and please upload pictures or videos of the problem.
Jan 26, 2023 at 12:28 PM
ECKERT-HICKS JANINE
Thank you. I will check it out when I get home. And let you know what happens.
Jan 26, 2023 at 4:31 PM
ECKERT-HICKS JANINE
It's the fuel injectors. They are clogged. I haven't been able to take pictures but I will definitely take them when I get a chance to clean the injectors.
Jan 31, 2023 at 5:28 PM
Yep, good find, I am glad you are on your way to fixing the problem, please let me know how it goes.
Feb 2, 2023 at 1:06 PM
