Have your mechanic perform a chemical test at the radiator. That will identify if a head gasket is leaking. You can also add a small bottle of dark purple dye to the coolant, then check later with a black light. The dye will show up as a bright yellow stain. If a head gasket is leaking, you'll find the dye inside the tail pipe.
Mar 21, 2017 at 7:29 PM
