Most likely, the rheostat is bad on the float gauge in the tank. A rheostat is basically an electrical device that controls voltage by resistance. As the float raises in the tank, resistance is lessened allowing more power to make it to the fuel gauge. When the float is low, resistance is high and less power is sent. What happens is the rheostat is likely bad in the section.
I attached a pic of the pump assembly. I circled the rheostat and highlighted the float.
Let me know if you have questions.
May 30, 2020 at 7:48 PM
