gas gauge not working properly?
2003 CHRYSLER PT CRUISER
5,700 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
JERRYSIDDOCK
  • 58 POSTS
when starting the gas gauge goes to full and then goes to empty.
Oct 10, 2024 at 8:25 AM
It sounds like you have a bad ground at the right front fender, here is the gas gauge wiring diagrams which shows the ground they I would check. Blk/lt grn wire. Check out the images (below). Let us know how it goes.
Oct 10, 2024 at 3:31 PM
JERRYSIDDOCK
  • 58 POSTS
i took off both multi tab ground connectors, scraped the mating surfaces and put it back together. still when i turn the key to the run position the needle goes to the top and a couple seconds later it drops off. does the gauge depend on this ground when the key is first turned to the *Run position?
Oct 11, 2024 at 2:24 PM
JERRYSIDDOCK
  • 58 POSTS
before i get too far afield, the button below the odometer screen goes from the odometer to trip and back to odometer. does the 03 not have trip A, trip B, temperature, odometer.
Oct 11, 2024 at 3:15 PM
Okay, this will be a cluster problem or a ground to the cluster, I would check the ground wire by removing the cluster connector and checking the black wire.
This guide can help:
Make sure the cluster wiring is disconnected before the test. Here is how to remove the cluster. If the ground is good the cluster is probably bad and needs to be sent in for repairs or get a used cluster by searching eBay.
Oct 13, 2024 at 8:40 AM
JERRYSIDDOCK
  • 58 POSTS
found it. a mouse or something had opened up two wires at the molex connector just after the wires make a 90°, (after coming down from the top of the tank), and heads toward the front of the car. there were two other breaks along the way. thank you for your help.
Oct 20, 2024 at 4:18 PM
JERRYSIDDOCK
  • 58 POSTS
Now i have a P0344 and P0339 codes, Cam Shaft Position sensor A circuit intermittent Bank 1 or single sensor, sensor A circuit intermittent. Where is the sensor circuit located, any idea? (I've already changed the crankshaft position sensor)
Oct 21, 2024 at 8:51 AM
JERRYSIDDOCK
  • 58 POSTS
gg
Oct 21, 2024 at 8:55 AM
Glad you could get it fixed, thanks for letting us know. Please use 2CarPros anytime we are here to help.
Sorry, we only handle one problem per thread, please post your new question here, you must be logged in.
Oct 21, 2024 at 9:53 AM
