Gas gauge, temperature gauge and heater are not working
2005 CADILLAC CTS
250,000 MILES • 3.6L • 6 CYL • RWD • AUTOMATIC
PATCHES DAVIDSON
My gas gauge and temperature gauge does not work. also, my sunroof and sport button and snow button and lights on gear shift do not work. the drivers side heat blows cold and the heated seats do not work, but they work on passenger side. I have checked the fuses and there good.
Oct 29, 2016 at 9:03 AM
HMAC300
  • 48,601 POSTS
have a mechanic scan for codes as it may be a body module problem. also, check battery for condition including load test. make sure terminal ends are clean and finally pull HVAC fuse inside car for sixty seconds with key on it may reset actuator for heat on drivers side.
Oct 29, 2016 at 9:54 AM
