So you do have 268,000 miles on your car? Also, if you have never changed the spark plugs I would start by doing that use the original equipment type of plug to try to take care of the code p0300 random miss fire and the p0305 cylinder five misfire. How does the engine run smooth? Also, how does it shift smooth? Usually the p1811 long term shift adaptives set to default code is set by a faulty line pressure solenoid in the transmission valve body and you will get a hard shift until you turn the car off and on then it will shift normal until it acts up again. Do you smell the fumes in the front of the car back of the car middle of the car? Can smell the fumes with the car not running?
Jan 6, 2018 at 10:34 AM
