I've tried 3 different gas caps on the filler neck. Two normal ones and a locking one. The caps all click in place like they should but once the car is started and the gas tank is under pressure, the caps pop back open.
The newest thing I've done to try troubleshooting is I actually replaced the entire filler neck from a 2005 Toyota Matrix at the salvage yard. Great condition, no holes in the soft hose and no corrosion or rust on the rest. I changed it because I figured the issue was my old one just being worn down over the years but it's having the same exact problem. The caps click but loosen under the tanks pressure once the car is started.
I'm so confused on what to do next it's really unmotivating lol.
Any ideas or advice are appreciated!
Aug 16, 2022 at 12:45 PM
