A friend brought me his car that has been parked for 2 years, it used to start and run fine. A friend of his wanted to install a push button to start it so he started the job by running a wire from the starter to the front but never did finish it, i disconnected the starter wire he added, ignition wire was never connected. So he wants me to just get it right And sell it. I put a new battery in it and there is nothing no power whatsoever. When they towed it they disconnected the linkage between the electrical gearbox and the shifter underneath which is a pin. I out that back but the steering column shifter still at free play you can change hears freely no resistance. I think the gear selector has an electrical part that must have power for the gear selector to work cause it is not a cable. Is there a fusible link on these cars? I just need to see why there is no power even with a battery.
Jun 4, 2021 at 8:29 AM
