The engine management fuse in my car keeps blowing as soon as i put one in. It is a 7.5 fuse.
Dec 12, 2016 at 12:30 PM
SATURNTECH9
CERTIFIED EXPERT
Something is shorted out ether a component or wire. You can get a bulb test light and hook it across where the fuse goes. It should light up bright then you can move wires around and unplug things to see if the light dims or goes out to narrow down where your problem is.
Dec 12, 2016 at 12:41 PM
MISCHELE
MEMBER
Would the component be run by that particular fuse? Is there any way to narrow down my search?
Dec 12, 2016 at 12:51 PM
MISCHELE
MEMBER
The engine management fuse controls the heater blower, gauges, radiator fan, and the power wire that runs from the alternator to the switch. Where would i begin troubleshooting? The fuse will work for a very short amount of time then blow. I have a light tester.
Dec 12, 2016 at 12:54 PM
SATURNTECH9
CERTIFIED EXPERT
It could anywhere that fuse feeds power to. use your light tester across the fuse slot that keeps blowing with the key in the "run" position? Let me know if the fuse is bright dim etc.
Dec 12, 2016 at 1:40 PM
MISCHELE
MEMBER
It glows bright when you first put it in If it does not blow immediately. Other times it may not blow for up to thirty minutes. Thank you for helping.
Dec 12, 2016 at 2:04 PM
SATURNTECH9
CERTIFIED EXPERT
What is the location number of the fuse that keeps blowing?
Dec 12, 2016 at 8:09 PM
MISCHELE
MEMBER
It is the engine management fuse under the dash. It is a 7.5.
Dec 13, 2016 at 10:55 AM
MISCHELE
MEMBER
Its the engine managment fuse under the dash. It is a 7.5
SATURNTECH9
CERTIFIED EXPERT
I do not see a fuse called that. can you please tell me the fuse location number like I asked for before?
Dec 13, 2016 at 12:42 PM
MISCHELE
MEMBER
It is #30.
Dec 13, 2016 at 12:50 PM
SATURNTECH9
CERTIFIED EXPERT
That number in the inside fuse box is the electronics fuse. I posted a picture that tells what it powers. I would start unplugging components while watching the test light to see how it affects the light.
