Fuses
2002 MERCURY MOUNTAINEER
181,000 MILES • 4.0L • 6 CYL • AWD • AUTOMATIC
MARK MAKAREWICH
  • 10 POSTS
For the high circuit breakers is it as easy as looking at them and visually see if they are burnt looking from the top down into them?
Jun 29, 2017 at 8:48 PM
STEVE W.
  • 15,113 POSTS
If you mean the large fuses, usually you can tell they are blown by looking, but they can fail at the ends of the strip and look okay.
The better way to test them is to use a test light. You connect the clamp end to a good ground. Then use the tip to probe the contacts on top of each fuse with the key in the on position, and the headlights on. You can run through every fuse on a typical car in about five minutes that way.
https://www.2carpros.com/articles/how-a-car-fuse-works
Jun 29, 2017 at 10:05 PM
MARK MAKAREWICH
  • 10 POSTS
Thank you.
Jun 29, 2017 at 11:04 PM
