Got it. That helps. This is the fuse solely for the compressor so either you have an issue in the wiring or loose ground. Or more likely the compressor is the issue and it is drawing too much current and blowing the fuse.
So I am concerned when you say that you had the front and rear compressor replaced as I am only seeing one compressor as it is rare that you would have a compressor for the front and rear. The two axles need to work together so they should run off the same compressor. Are you should you didn't have the front and rear dampening units replaced? Do you have the part numbers of what they replaced?
Oct 10, 2020 at 1:40 PM
