License plate lights are not working
2011 TOYOTA 4RUNNER
117,020 MILES • 4.0L • V6 • 4WD • AUTOMATIC
KEVIN DIMOCK SR.
i replaced the bulbs still not working. where is the fuse located for the license plate lights.
Thank you,
Kevin Dimock Sr.
Jun 1, 2020 at 12:38 AM
Good morning,
Okay, there is no individual fuse for the license light. It has a green wire that goes to it and all the rear parking lights run off this green wire. If the regular running lights are working then there could be a wiring issue.
https://www.2carpros.com/articles/no-tail-lights-exterior-running-lights-tail-lights-out
Use a test light or voltmeter and test the green wire at the socket for power with the lights on.
Here are the fuse locations you asked for and a guide to check them:
Jun 1, 2020 at 2:47 AM
KEVIN DIMOCK SR.
Perfect answer my friend. sounds like an easy fix.
Thank you very very much.
God bless.
Have a wonderful day.
Kevin Dimock Sr.
Jun 1, 2020 at 10:21 AM
ASEMASTER6371 is one of our best! Please let us know if you need anything else to get the problem fixed.
Jun 1, 2020 at 10:29 AM
