Did you verify that the fuses are the cause of the draw?
GEM module
REMOVAL
1. Disconnect the battery ground cable. For additional information, refer to Battery.
CAUTION:
^ Prior to removal of the module, it is necessary to upload module configuration information to the appropriate scan tool. This information needs to be downloaded into the new module once installed. For additional information, refer to Module Communication Network (Information Bus).
^ Electronic modules are sensitive to static electrical charges. If exposed to these charges, damage may result.
2. Remove the instrument panel steering column cover.
1 Unlock the retainers.
2 Remove the instrument panel steering column cover.
CAUTION: Use care when removing the instrument panel steering column cover or damage to the cover locating tab may occur.
3. Loosen the bolts and disconnect the bulkhead connectors from the instrument panel fuse junction panel.
4. Position the instrument panel fuse junction panel aside.
1 Remove the nuts.
2 Remove the bolts.
5. Remove the Generic Electronic Module (GEM).
1 Disconnect the electrical connectors.
2 Remove the screws.
3 Remove the GEM.
INSTALLATION
1. To install, reverse the removal procedure.
CAUTION: Once the new module is installed, it is necessary to download the module configuration information from the scan tool equipment into the new module. For additional information, refer to Module Communication Network (Information Bus).
The neutral switch is on top of the transmission under the hood.
Mar 25, 2019 at 3:13 AM
