Power window systems rarely use fuses. Being considered a safety system, they are normally protected by auto-resetting thermal circuit breakers. When they trip, they will try to reset within about half a minute to make the system functional, if only for a short time. If all the windows are dead in both directions, a better suspect is broken or frayed wires between the driver's door hinges. One potential clue is the system might work intermittently as you open and close the driver's door.
Jul 28, 2017 at 7:57 PM
