fuse #13 in engine compartment keeps blowing
2000 MITSUBISHI ECLIPSE
142,854 MILES • 4 CYL • 2WD • MANUAL
AGEL
  • 40 POSTS
i was driving and it just turn off. i check the fuses i found number thirteen blown. i replaced the fuse and it runs for a little bit then it turns off again.
Feb 22, 2018 at 4:35 PM
The #13 fuse goes to the cooling fans engine controls and air conditioner. The first thing I would check is the cooling fan, with the engine off open the hood and see if you can rotate the cooling fan it should turn freely.
Please let us know what you find.
Feb 28, 2018 at 10:06 AM
AGEL
  • 40 POSTS
good evening i check the fan and its ok i disconnected and put a new fuse try to star the car and it blew up the fuse again. I try connect the scanner to diagnose the car but it shows an error. Could you send me images of were the ecm is located please?
Feb 28, 2018 at 2:12 PM
It looks like the ECM is under the hood on the drivers side here is a diagrams of its location (below). I would test the ignition coils and fuel injectors.
https://www.2carpros.com/articles/how-to-test-a-fuel-injector
and
These can build up high resistance causing the fuse to blow.
Mar 1, 2018 at 11:35 AM
AGEL
  • 40 POSTS
i still cant find what keeps blowin the fuse
i already check alternator,starter,fan,ignition ,switch,coils elictrical conetor but no luck finding the problem
Mar 2, 2018 at 9:20 AM
I would disconnect all oxygen sensors, you can drive it without them to test.
Mar 2, 2018 at 10:18 AM
AGEL
  • 40 POSTS
car wont star it cranks but wont star fuse n#13 keeps blowing up
Mar 2, 2018 at 10:20 AM
AGEL
  • 40 POSTS
it wont even let me scan the car
Mar 2, 2018 at 10:21 AM
CARADIODOC
  • 34,306 POSTS
A simple trick to finding a short is to replace the blown fuse with a pair of spade terminals, then use small jumper wires to connect them to a 12 volt light bulb. A brake light bulb works well. When the circuit is live and the short is present, the bulb will be full brightness and hot so be sure it's not laying on the carpet or against a plastic door panel. Now you can unplug electrical connectors and move things around to see what makes the short go away. When it does, the bulb will get dim or go out.
Mar 2, 2018 at 12:19 PM
That fuse feeds the ignition switch can you unplug it and see if it happens?
Mar 2, 2018 at 2:03 PM
AGEL
  • 40 POSTS
it blows the fuse when i turn the gniton switch to star the car i trya new switch butstill does the same
Mar 3, 2018 at 9:57 AM
AGEL
  • 40 POSTS
how could i check if the ecm is bad
Mar 3, 2018 at 9:58 AM
You cant only a electronic repair shop can. If you unplug the ECU does it pop the fuse?
Mar 3, 2018 at 1:26 PM
AGEL
  • 40 POSTS
No it doesnt pop the fuse without the ecu disconected
Mar 3, 2018 at 3:46 PM
All right getting warmer. Plug the ECU back in and disconnect all oxygen sensors and retry the test.
Mar 5, 2018 at 10:24 AM
AGEL
  • 40 POSTS
Could any one send me wiring diagrams for the ecm 2000 eclipse
Mar 6, 2018 at 10:26 AM
Yep got you covered, here are the full wiring diagrams for the engine and a guider to help you do some testing.
Did you try the oxygen sensors?
Mar 6, 2018 at 12:58 PM
AGEL
  • 40 POSTS
I diconected the two oxigen censors and it keeps blowing the fuse
Mar 8, 2018 at 3:46 PM
Ignition coil, fuel injectors are next. Please disconnected and see if the fuse still blows
Mar 9, 2018 at 12:48 PM
AGEL
  • 40 POSTS
I already try that and it kept blowing the fuse
Mar 9, 2018 at 4:56 PM
Test all computer wiring to ground if everything checks out replace the ECU.
Mar 9, 2018 at 6:03 PM
AGEL
  • 40 POSTS
Ok las thing i did is try star the car without the ecm conected and the fuse blew up
Mar 12, 2018 at 5:34 PM
AGEL
  • 40 POSTS
I dont know what alse to check
It sounds like the ECM is shorted out and you need a used or new one. I would send it out to have it rebuilt.
Mar 13, 2018 at 10:08 AM
AGEL
  • 40 POSTS
Do you a place to rebuilt it
Mar 13, 2018 at 10:29 AM
Check ebay most of our guys use services from there. Also you might want to open it up to check for water damage in which case it may be junk
Mar 13, 2018 at 11:05 AM
AGEL
  • 40 POSTS
Ok thanks
Mar 13, 2018 at 11:07 AM
AGEL
  • 40 POSTS
One more thing why did the fuse blew up without the computer been conected
Mar 13, 2018 at 11:08 AM
CARADIODOC
  • 34,306 POSTS
Did you try my suggestion of replacing the fuse with a light bulb?
Mar 13, 2018 at 5:59 PM
AGEL
  • 40 POSTS
could you show me where the ignition failture is located
Mar 14, 2018 at 1:42 PM
CARADIODOC
  • 34,306 POSTS
You've been replacing a fuse, so you know where it is. Put a light bulb in there instead of a fuse. A typical brake light bulb will limit current to around one amp so the wiring will be protected. When the circuit is turned on and the short is present, the bulb will be full, normal brightness. Hang it where you can watch it while you unplug stuff and move wiring harnesses around. When you do anything that removes the short, the bulb will turn off or be dim. In some cases, depending on what else is in that circuit, the bulb may only dim a little when the short is removed so you have to watch closely while you move stuff.
Mar 14, 2018 at 3:43 PM
