My Fuse number ten in the engine box has blown twice now. The first time it happened, the coolant level indicator and check engine light turned on simultaneously. The second time, the coolant level indicator light turned on, with the check engine light following after ten miles. Is it possible that a bad coolant level sensor is causing the fuse to blow?
Jan 21, 2017 at 1:14 AM
