Hi, I was browsing the Advance Auto Parts website and I found out that my vehicle listed above SV has a crankshaft position sensor, two camshaft position sensors, as well as a knock sensor and it doesn't have a throttle position sensor, I am aware that the crankshaft position sensor and two camshaft position sensors time the four direct ignition coils to produce the high voltage spark plug electricity but what triggers the crankshaft and camshaft sensors to temporarily interrupt the flow of low voltage electricity to each ignition coil so that high voltage electricity can form or be induced? Is it a lobed trigger wheel reluctor in the crankshaft and camshafts or a toothed trigger wheel reluctor on all three of them like the toothed wheel of the long-ago distributor? I also saw on the Advance Auto Parts website that this vehicle has a knock sensor, and I am aware that a knock sensor retards ignition timing in the case of a spark knock but does it also retard ignition timing in the case of a rod knock? It's a microphone style sensor so could it sense both a spark knock and a rod knock? I also saw in the Advance Auto Parts website that no throttle position sensor is available for this vehicle, does the electronic gas pedal do the work that the throttle position sensor used to do in older cable-operated gas pedals? I also saw in the Advance Auto Parts website that just one oxygen sensor is priced at over $500 dollars in this vehicle and this vehicle has two oxygen sensors so if the oxygen sensor goes bad or awry or errant does the vehicle fail to start altogether or does it run with the check engine light on in the open loop mode? I am asking because I am noticing that the oxygen sensor is pretty expensive so I need to know whether the vehicle will fail to start if this sensor fails, or will it just run poorly? that's all folks and thank you in advance for answering my curious questions.
Feb 4, 2023 at 3:23 AM
