Yes, the Purge Valve is pulse width modulated, the ECM does this to control exactly how much fuel vapor is entering the engine, it will purge the Evap system at different times depending on a number of variables. But since your fuel trims get better while you're driving it sounds like you have a large vacuum leak. I say this because when the throttle plates are closed, such as at an idle state, the intake manifold has high vacuum. When you're driving and the throttle plates are open or partially open, this lowers the manifold vacuum. This is why at idle a vacuum leak will be worse, because there's more vacuum and more air is being drawn in due to the difference in pressures outside the engine and inside.
When the throttle plates are open, manifold vacuum drops and less air is drawn in, so the ECM has less to compensate for. This is called "False Air" because it is not being measured by the ECM.
This car has a Mass Air Flow sensor (MAF), and the vacuum leak wherever it is (i.e., intake manifold gasket,) the MAF cannot measure that air coming in and your fuel trims go positive because the ECM is adding fuel to make up for the extra false air.
So, at idle is when you're going to want to search for the vacuum leak. The +1.6 and +3 are great numbers.
Here is a guide below to help you find the leak. Look for old vacuum lines that could be broken or rotted apart. Try blocking off the Brake Booster hose that goes into the intake manifold.
i usually use a smoke machine to find vacuum leaks, but I also use a spray bottle with just water. If you spray around the intake manifold gasket area and listen carefully you can hear the water being sucked into where the vacuum leak is.
Some people will use a propane or brake cleaner and listen for the rpm to raise when you're around the leak. But I prefer to start with water, not a flammable spray. Thats a last resort.
Watch your fuel trim numbers, if you can find and block the leak, the trim numbers will come down pretty quickly.
If you suspect the Purge valve issue, just unplug it, or block its hose to the intake manifold temporarily. See if that helps. Let us know how it goes.
Mar 5, 2022 at 4:58 PM
