Fuel tank pressure switch, no start
1997 HONDA PASSPORT
168,000 MILES
DANIAL LARSON
When I drop the tank to do the fuel pump I forgot to disconnect the pressure switch and cracked it on the outside at the base. Can I bypass that pressure switch. And will it cause the motor not to start pump primes doesn't seem to run. I bypassed relay run a fuel pump still no start probably combination of. Fuel pressure center on fuel rail squirted gas when remove vacuum hose assuming broken diaphragm and broken fuel tank switch. will a tank switch make the car not run fuel pump relay was bypassed, still no start?
Mar 6, 2019 at 4:14 PM
DANIAL LARSON
That's the pressure regulator switch. is there anything I should know about taking that off that I don't assume by looking at it? intake manifold have to come off question 1.
Mar 6, 2019 at 9:13 PM
The best way to go is run the codes that will tell you if the pressure switch is causing the issue. Here is a guide to help us get started:
Mar 9, 2019 at 1:39 PM
