Fuel tank hose
2003 PONTIAC GRAND AM
129,327 MILES • 6 CYL • 2WD • AUTOMATIC
RAY72ARAIZA
I removed a hose from the fuel tank to where you put the gas in and a little blue tube like plastic plug fell out.which way does that go back in?
Mar 5, 2018 at 11:23 PM
MHPAUTOS
  • 31,937 POSTS
can you post a picture so i can see it? not sure but i may be a vent one way valve.
Mar 6, 2018 at 12:55 AM
RAY72ARAIZA
Here is a picture of what I am talking about.
Mar 6, 2018 at 3:08 AM
MHPAUTOS
  • 31,937 POSTS
i would think arrow end first, is it a valve can you blow through one end and not the other? i will let others look at this as i am not exactly sure at this point.
Mar 7, 2018 at 12:31 AM
It looks like a gas can adapter that fell into the fill hose to me.
Mar 8, 2018 at 3:57 PM
SATURNTECH9
  • 30,869 POSTS
There should not be anything in that tube. I have seen anti roll over balls that are placed right where fuel actually goes into the tank. Were you having trouble filling the tank at the gas pump?
Mar 8, 2018 at 8:04 PM
STEVE W.
  • 15,113 POSTS
That is a can adapter like Ken mentioned. They hold the small flap open so you can add gas into the tank. Without them the flap stays closed and you cannot get gas into the tank.
Some sneaky folks also use them to run a small line into the tank to steal gas.
Mar 9, 2018 at 12:07 AM
MIKE H R
  • 3,094 POSTS
I agree with Steve and Ken, looks like it has been used a few times.
Apr 19, 2018 at 10:36 AM
