Good afternoon.
Below are the steps and pictures for you.
Removal
1. Warning:
- place the vehicle in a quarantined area and arrange no smoking/petrol fume signs about the vehicle.
- Before any work is carried out on the fuel system, ground the vehicle to earth and maintain the ground connection until the work is complete.
- Do not smoke or carry lighted tobacco or open flame of any type when working on or near any fuel related components. Highly flammable vapors are always present and may ignite. Failure to follow these instructions may result in personal injury.
- The fuel system remains pressurized for a long time after the ignition is switched off. The fuel pressure must be relieved before attempting any repairs. Failure to follow these instructions may result in personal injury.
- After carrying out repairs, the fuel system must be checked visually for leaks. Failure to follow these instructions may result in personal injury.
- This procedure involves fuel handling. Be prepared for fuel spillage at all times and always observe fuel handling precautions. Failure to follow these instructions may result in personal injury.
- If taken internally do not induce vomiting, seek immediate medical attention. Failure to follow these instructions may result in personal injury.
- If fuel contacts the eyes, flush the eyes with cold water or eyewash solution and seek medical attention.
- Wash hands thoroughly after handling, as prolonged contact may cause irritation. Should irritation develop, seek medical attention.
Drain the fuel tank.
2. Remove the driveshaft.
imageZoom/Print
3. Remove the fuel tank filler pipe to fuel tank hose.
imageZoom/Print
4. Remove the fuel tank heatshield.
1. Remove the fuel tank heatshield retaining nuts.
2. Remove the fuel tank heatshield.
imageZoom/Print
5. Disconnect the fuel tank electrical connector.
imageZoom/Print
6. Disconnect the evaporative emission pipe.
imageZoom/Print
7. Caution: When supporting the fuel tank, use a suitable packing material to prevent damage to the underside of the fuel tank.
Remove the fuel tank.
- Detach the fuel tank support straps.
Aug 20, 2018 at 9:16 AM
