If you guys can provide me with the diagram for the fuel system. I installed a new fuel pump, and I checked it twice. I have a vapor lock, can only put a few gallons in the tank then fills up at the filler neck. Which hose is the return hose that might be bent. Also, the gas gauge doesn’t change since I replaced the fuel pump.
Apr 2, 2024 at 6:02 AM
