Fuel system
1996 GMC JIMMY
168,642 MILES • TURBO
BELINDA SOUTH
Gets fire, but not fuel and map sensor light has came on and off a few times.
Dec 30, 2017 at 10:32 AM
Good morning.
The most common failure for no fuel is the fuel pump. A fuel pressure test will confirm. You need to test the pressure at the test port on the fuel rail. If you do not have a tester, you can rent one at a parts store.
As far as the Map sensor light, what code is set for you to think this is a issue?
Dec 31, 2017 at 3:52 AM
