fuel system
2000 LINCOLN CONTINENTAL
115,000 MILES • 3.4L • V6 • 2WD • AUTOMATIC
CHEVIGUY
I had a weak battery so changed it and now I am getting no power to fuel pump. Everything else works normal. I checked inertia shut off switch and it seems okay. Went through fuses, but find no dedicated fuse to fuel pump.
Aug 21, 2017 at 8:38 AM
I found the wiring diagram for the fuel pump and a guide to help you do check quick tests to see where you are loosing the power at.
and
Aug 22, 2017 at 11:25 AM
