Fuel system
1993 LEXUS GS 300
240,000 MILES • 3.0L • 6 CYL • RWD • AUTOMATIC
KEVNLKING
  • 26 POSTS
How do you disable the fuel system when changing the fuel filter? When i changed it the last time fuel continued to come out the fuel line. Most cars that i have changed fuel filters on the gas eventually stops.
Aug 23, 2017 at 12:43 PM
STEVE W.
  • 15,113 POSTS
You have to discharge the pressure in the system. On most you remove the fuel pump relay or fuse. Start the engine and let it run until it shuts down. Then change the filter. You will still get leakage but it should not be as bad.
Aug 23, 2017 at 1:11 PM
