Which line coming from tank goes to which side of fuel rail?
1998 FORD WINDSTAR
100,000 MILES
FROSTDUDE
Fuel system diagram needed.
Jun 10, 2022 at 5:28 PM
BRENDON S
  • 653 POSTS
I need a little more info from you. It looks like this year came with two different engine sizes. A 3.0L or a 3.8L. Do you happen to know which engine you have?
I also need to know if it is a Base, GL, Limited or LX
If you don't know that's okay, if you give me your 17-digit VIN, I can see everything about your vehicle and find the correct diagram for you.
If you are not sure where to find it, that's ok. The VIN is located on the driver's side at the bottom of the windshield. You can also find it on the driver's side door jam. I usually stay away from this one personally because it's usually on the door side instead of the car side and you never know if the door has been replaced, well unless you have owned it from new. You can also find it on your registration and in some states on your inspection sticker.
Just want to make sure we are giving you the most accurate information we can. Let me know if you are having trouble finding the information.
Thank you,
Brendon
Jun 11, 2022 at 12:04 AM
