Fuel smell in the exhaust
2010 MITSUBISHI LANCER
80,000 MILES • 2.0L • 4 CYL • TURBO • 2WD • AUTOMATIC
PH KONG
I had my gearbox replaced about a month ago and since then, there is a strong smell of petrol from the exhaust. What can be the cause ?
Jan 3, 2019 at 6:42 AM
Hi and thanks for using Overdrive
They would have had to remove the exhaust system. Check and confirm that the oxygen sensors are connected and the wiring isn't damaged.
I attached 3 pictures to help you locate the sensors. Check all of them.
Note: If the check engine light is staying on while the engine is running, you need to have the computer scanned to determine the diagnostic trouble code. Here is a quick video that shows how it is done:
https://youtu.be/YV3TRZwer8k
Here are a couple links that describe what an oxygen sensor does and how one is replaced:
https://www.2carpros.com/articles/how-an-oxygen-sensor-works
https://www.2carpros.com/articles/how-to-replace-an-oxygen-sensor
Also, I would like you to check one more thing if the sensors are good. The engine coolant temperature sensor can be causing issues and I feel confident that it was disconnected too. The last picture I attached shows its location. Make sure it is connected and there is no wiring damage.Take a look through these links for symptoms and how one is replaced.
https://www.2carpros.com/articles/symptoms-of-a-bad-coolant-temperature-sensor
https://www.2carpros.com/articles/coolant-temperature-sensor-cts-replacement
Let me know if this helps.
Jan 3, 2019 at 9:31 PM
