I cannot get my fuel gauge to work properly and seem to be getting ten volts at times. I have seen it work properly at times when I am getting five volts which is where it should be. Any suggestions? I have checked the ohm readings from the sending unit and they seem to be good at eighty empty four at full. The voltage at the fuel pump harness should be five but I am seeing ten which I believe is causing my problem. The gauge will not go below about 2/3 of a tank.
Dec 24, 2017 at 1:26 PM
