Login
Join
Home
Answered Questions
Repair Topics
Repair & Service Guides
Popular Questions
Warning Lights
Trouble Codes
How It Works
Testing / Diagnostics
Symptoms
Videos
Login
Become a Member
Home
Lincoln
LS
Fuel System
Fuel Level Sensor
Replace/Remove
Fuel sending unit
2004 LINCOLN LS
225,000 MILES
RUSSELL WALKER
MEMBER
1 POST
FOLLOW
Replaced pump, fuel pressure regulator, filter, starts then stalls. need to know how to check the fuel pump sender on the driver side?
Aug 7, 2019 at 3:46 PM
CERTIFIED EXPERT
It sounds like you want to check the fuel pressure? This guide will help with the location of the pressure port in the diagrams below:
Check out the diagrams (below). Please let us know if you need anything else to get the problem fixed.
Aug 8, 2019 at 12:18 PM
