Do you know of a 90 degree offset fuel fitting for the vehicle listed above Ford fuel schrader to Ford schrader valve on the fuel rail pressure tester? The electrical harness and vacuum line for the fuel rail pressure damper are all in the way to get fuel pressure tester hooked up know of a better way that works . Thanks.
Aug 28, 2020 at 3:17 AM
