Is the fuel regulator also a part of the fuel pump assembly?
2005 SATURN RELAY
260,125 MILES • 3.5L • 6 CYL • 2WD • AUTOMATIC
DONABUNDANCE123
  • 4 POSTS
Fuel regulator.
Nov 24, 2024 at 3:17 PM
The fuel pressure regulator is part of the primary fuel tank module. You need to remove the module/pump to access it.
I attached a picture below showing its location. Also, I attached the fuel pressure specifications as well. Are you outside of the specs?
See pics below.
Nov 24, 2024 at 6:36 PM
DONABUNDANCE123
  • 4 POSTS
Once I install the new fuel pump will my car crank right up?
Nov 25, 2024 at 2:13 PM
Is the fuel pressure too high or low? As far as will it start, I can't answer that because I don't know all the details. If you purchase a new pump, make sure it is the pump assembly if you feel the regulator is faulty.
Nov 26, 2024 at 9:21 PM
