Fuel rail pressure sensor location
1999 LINCOLN CONTINENTAL
90,000 MILES • 4.7L • V8 • 2WD • AUTOMATIC
STUART BROWNSTEIN
  • 4 POSTS
Check engine light came on, code P0190. where is the fuel rail pressure sensor located?
Apr 8, 2019 at 10:01 PM
CARADIODOC
  • 34,306 POSTS
P0190 - Fuel Rail Pressure Sensor Circuit Malfunction
It's on the fuel rail that feeds the injectors. This is the best drawing I could find.
Be aware diagnostic fault codes never say to replace a part or that one is bad. When a part is referenced in a fault code, it is actually the cause of that code about half of the time. First we have to rule out wiring and connector terminal problems before spending your money on a part.
Apr 8, 2019 at 11:43 PM
STUART BROWNSTEIN
  • 4 POSTS
Thank you for your answer to this. Yes, the part, (depending where you source it from) can be rather "pricey". Stuart.
Apr 9, 2019 at 6:38 AM
CARADIODOC is one of our best! Use 2CarPros anytime, we are here to help. Please tell a friend.
Apr 11, 2019 at 9:46 AM
